It is currently Fri Sep 25, 2026 10:10 pm
PostPosted: Mon Dec 22, 2025 6:30 pm
Hey all, just hoping to get some help grading this board. It has a visible gold finger and some OCs as well as Ethernet ports with visible gold. Is it a gold edge CNC, high grade telecom? If I chop the gold fingers off is it eri high grade telecom?
Thanks all
PostPosted: Mon Dec 22, 2025 7:46 pm
I would remove the 3 toroid transformers by J12. The PCB is definately not Gold Edge. When you referred to OCs. Do you mean optical couplers? If so. That's meaningless to grade. Also. What do you mean eri?.........Never the less.........After removing the 3 toroids. I would feel confident submitting as High Telecom. Hopefully some others will post some opinions. Cherry picking those gold fingers is a ?????? For me.
PostPosted: Tue Dec 23, 2025 3:26 pm
I think they had some autocorrect or tiny keypad troubles...
OC is likely ICS ¯\_(ツ)_/¯
I'm realizing I haven't watched all the YouTube grading videos that were added to the grades...
I would leave the fingers myself, do remove the transformers. After that high grade Telco
PostPosted: Tue Dec 23, 2025 9:41 pm
Thank you guys! I meant ICs so second guy is on the money
