It is currently Sat Nov 07, 2026 4:24 pm
PostPosted: Tue Mar 29, 2016 6:39 pm
PostPosted: Tue Mar 29, 2016 7:16 pm
Multiple options here.
As is you can probably toss them all in as mixed wire.
If you take the time to clean/cut them up you'll have gold and silver connectors, silver plated brass, ic chips etc. Cut the flat silver connectors off and put them as silver ram rate. The flat gold contacts can go gold fingers. Etc.
That way is a considerablly higher payout.
PostPosted: Tue Mar 29, 2016 8:11 pm
If you take the time to clean/cut them up you'll have gold and silver connectors, silver plated brass, ic chips etc. Cut the flat silver connectors off and put them as silver ram ratr. The flat gold contacts can go gold fingers. Etc.
Very cool information, thank you. Does board sort accept them
PostPosted: Tue Mar 29, 2016 10:32 pm
Yes. Everything posted... whole or separated.
PostPosted: Wed Mar 30, 2016 3:06 am
OK thank yall very much for sharing yalls knowledge
