It is currently Mon Sep 28, 2026 1:42 pm
PostPosted: Thu Jan 15, 2026 5:43 pm
What would these be considered? And should we remove anything before sending in?
PostPosted: Fri Jan 16, 2026 5:06 am
Midgrade. View the video under the Midgrade escrap price list. Nothing to clean that I can see. But. I am curious. What is that yellow cylinder component next to the fuse? It is tie wrapped to the board. Normally it is assumed to be a capacitor. Make sure it is. And not a battery. If it is. It should be removed before submitting to boardsort. Just a precautionary note. Probably a capacitor. But. Best to be 100% sure.
PostPosted: Fri Jan 16, 2026 11:54 am
You should snip your wires as close to the board as you can. You can choose to remove the aluminum heatsink (looks like you already removed a couple) if it's not insanely difficult to pull. The larger capacitors could be pulled too but I wouldn't bother unless you know you can get paid better for them than the board at midgrade, it'll also make the board take up a little less space if you need it.
PostPosted: Sun Jan 18, 2026 11:20 pm
You can remove the gold connector for higher pay
