It is currently Wed Sep 30, 2026 4:06 pm
 Post subject: Help grade some boards
PostPosted: Thu Jan 22, 2026 5:55 pm
Sorry about the board overload.
Board 1.jpg - I'm leaning toward Peripheral Low grade. Is there anything that could be removed to upgrade it?
Board 2.jpg - ?
Board 3.jpg - ?
Board 4.jpg - Possibly low peripheral
Board 5.jpg - Leaning toward low peripheral, maybe high. No junk on it, looks like some capacitors have been removed. Some chip density on the back.
Board 6.jpg - Maybe high Peripheral? little junk, just a few capacitors and some chip density.
Board 7.jpg - Leaning toward low peripheral. Is there anything that could be removed to give it an upgrade?
Board 8.jpg - Very light weight. I'm thinking high peripheral on it or maybe removing some capacitors and the 2 white and 1 black transformer to help it get there? It also has an Ethernet plug on the back with gold pins.
Board 9.jpg - Low peripheral or possibly high. Some decent chip density and light weight other then the AV ports.
Board 10.jpg - Leaning toward High Peripheral. The black connector has gold tipped pens. The rest of the connectors including one on the other side and the USB has all gold pins.
Ryan Keller
Keller's Custom Services
PostPosted: Thu Jan 22, 2026 7:43 pm
High peripheral: 1, 9
Low peripheral: 2, 7, 10
Midgrade: 3-6, 8 All of these might have some room to get low peripheral but I'm not confident enough to say.
PostPosted: Wed Jan 28, 2026 3:50 pm
Thank you for the help, I removed some heatsinks, capacitors and transformers from 2 and 7 so maybe i made room for it to be considered in high peripheral.
Ryan Keller
PostPosted: Sun Feb 01, 2026 2:26 pm
I agree with Marked, and I don't see any room for upgrade on these boards.
I would have removed the material from 2 in order to assure it to low peripheral. bordering mid-grade as shown. Don't see a way to high peripheral.
#7 low peripheral with a few tiny ICs, one small low quality flat pack, several gold connectors, some probable tantalum dipped capacitors and no really heavy junk.
#6 might slide through as a low peripheral, but it would be at the low end with a low quality flat pack, one small IC and a few small MLCCS. It does lack junk, but also no visible gold. I personally would throw it in mid-grade and move on.
#1 is a good example of the low to middle part of high peripheral. reasonably nice numbers of rectangular IC chips (including two ram chips), some gold connectors, a smattering of MLCCs, a modest sized flatpack, and some allowable junk in the form of non-gold connectors.
#9 is a little lighter on the chips and gold connectors, but still some quality putting it toward the lower end of high peripheral.
