It is currently Tue Sep 29, 2026 2:21 pm
PostPosted: Fri Jan 23, 2026 4:39 pm
What should I send this board as?
PostPosted: Fri Jan 23, 2026 6:29 pm
You need to remove at least the aluminum heatsink and the likely steel shield. Take another pic of that side after for an accurate grade.
PostPosted: Sun Jan 25, 2026 10:33 am
Remove the heat spreader and pop the metal top like mentioned; High Per once completed.
PostPosted: Mon Jan 26, 2026 7:52 pm
PostPosted: Mon Jan 26, 2026 8:24 pm
Yeah, should be high peripheral as Spence said.
