It is currently Wed Sep 30, 2026 12:11 am
 Post subject: Elevator board 3
PostPosted: Tue Jan 27, 2026 5:51 pm
Is this high peripheral?
The relays are really heavy.Should I remove them?
Do relays increase or decrease value for grading purposes?
Nothing on the bottom.
 Post subject: Re: Elevator board 3
PostPosted: Tue Jan 27, 2026 7:58 pm
Relays vary a bit. They have plastic, steel, copper, maybe brass and usually something more exotic on the contact points. The contacts would be the thing that makes them worth a little more or less. Overall they probably lower the value of this board a bit but I would leave them on as I think you can get high peripheral still.
PostPosted: Wed Jan 28, 2026 10:11 am
That is an above average relay. Made by SCHRACK. The SR6 series. They even are selling used on ebay. My comment here is focused on escrapping. Those contacts are a form of silver. Silver tin/silver oxide. It is a silver contact. Here is what I would do. A bit of mangling. First remove the plastic from the relay. Next. Cut out the relay coil.[copper]. Just leave the contacts on the board. So. You are removing weight. Junk. But leaving the cream [silver] for evaluation on the board. I would feel absolutely confident at High Peripheral. Even so. My suggestion. Has to be weighed against T=M. Time = Money. If I had 1000 of your boards pictured. Should I spend my time cleaning up the relays? Me personally. I have the time. Other scrappers. Don't.
