It is currently Fri Sep 25, 2026 11:56 am
PostPosted: Wed Feb 04, 2026 10:54 am
How would this board grade? TiA!
PostPosted: Wed Feb 04, 2026 3:11 pm
Nothing on the back?
I'm thinking high peripheral.
PostPosted: Wed Feb 04, 2026 5:46 pm
No, nothing on the back. Thanks for the input.
PostPosted: Fri Feb 06, 2026 4:34 pm
First of all. I am learning Escrap. But a tear down of your board is an option. A tear down as I understand so far from the forum. Your PCB seems to make more money than the individual submission. So my view of a tear down on your board is as follows.
. Desolder or cut off all connectors. I can't resist. I used to assemble that same connector. That is gold pin. Thru and thru. Remove the Dip Switch and other edge connectors. All those will go Connector Ends. Take the IC chips from the sockets. Of course. For them. IC Chip Category. Then you have Low/ Midgrade. If even Boardsort will buy it. It is just populated with resistor network stuff. Good luck.
That's my novice evaluation.
My evaluation advice is my own opinion.
PostPosted: Sun Feb 08, 2026 6:57 pm
What are these
PostPosted: Sun Feb 08, 2026 6:58 pm
TheCheeseMan wrote:
What are these
PostPosted: Sun Feb 08, 2026 10:45 pm
First post, High Per, but I believe it could push Low tel because those connectors are great although bulky but paired with all the ICs, it's a fair argument for Low tel; being fair High per. Those connectors can be silver plated Cu, Brass, too.
Board 1, High per
Board 2, High per; now... being a fair and genuine person that I am, I would remove all those screws from the input stands. Hardware, if not always, is ferrous material; steel. Steel in unwanted on the PCBs. Even though, that would be something of steel nature that's looked over. I choose to do it to make the recovery processes better.
