It is currently Thu Sep 24, 2026 9:48 pm
 Post subject: Should I remove these?
PostPosted: Sat Feb 14, 2026 4:14 pm
Hey, in the future, can I keep these two smaller DC power boards attached and still grade as high telecom? Thanks!
PostPosted: Sat Feb 14, 2026 6:46 pm
I would say under a general rule of law, if they are two individual boards in any way shape or form (That would be attached via a bracket, screws, zipties, or male-female connections each part is individual.
That said, #1 is HGT in my opinion
#2 (The one with tantalums) I can't tell what's on the back. A heat sink? Remove that and run with HGP
#3 (The one with transformers) ... Remove the three largest ones. Not sure if matters if the final tiny one is there or not but I'd run with HGP with that if you do so
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Sat Feb 14, 2026 8:02 pm
Sorry, I just realized my post is kinda confusing. lol. Pic 1 and 2 are front and back of the same card. Pic 3 and 4 were removed from pic 2. I have been removing them because they have aluminum tops and I thought that leaving them attached would downgrade the card as a whole. If I can leave them attached and still retain a high telecom grade, that would be ideal.
PostPosted: Sat Feb 14, 2026 9:35 pm
Telco isn't something I excel at grading so take this with a grain of salt, I'm leaning low Telco on the main board regardless.
The two smaller boards, assuming the aluminum was removed, following kandroids numbers, 2 can probably get low peripheral as is and I don't think it can go higher without the transformers. 3 has a type of transformer also with steel clips holding down the tops. If you can pull the clip and the top half to remove junk weight, high peripheral.
PostPosted: Sun Feb 15, 2026 1:10 am
Make sure to not remove the gold looking heat sink suspended in the middle of the board. That's a goodie
PostPosted: Sun Feb 15, 2026 1:26 am
oh yeah! I have quite a few of those boards. sometimes they pop off, so I have a bucket full of them, lol
