It is currently Sat Nov 07, 2026 2:01 pm
PostPosted: Wed Feb 18, 2026 7:25 pm
Good day fellow e-scrappers:
I have this board which came out of a Honeywell infrared motion sensor.
The board has the following immediately interesting components:
3x visible IC Chips
1x infrared image sensor
2x pronounced gold contact points.
1x located on the bottom left of the board (Gemini) says this is a Siward Quartz Crystal Oscilator
I could use a little insight on what the council would suggest for grading purposes.
Thanks again!
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Thu Feb 19, 2026 7:11 pm
leaning toward high peripheral
PostPosted: Fri Feb 20, 2026 4:32 pm
Those are mid grade boards, regardless of where they come from.
PostPosted: Fri Feb 20, 2026 8:42 pm
Worst case I'm seeing low peripheral. Between the ceramic oscillator, IC, gold plated pins (contacts) and gold on the board, I still lean high peripheral. Not sure if the infrared sensor does much for it or not
PostPosted: Fri Feb 20, 2026 8:52 pm
High per
