It is currently Wed Sep 23, 2026 4:13 pm
 Post subject: Help grading some boards
PostPosted: Tue Mar 03, 2026 2:47 pm
Would these go as peripheral high-grade Or low-grade
1 - 4 have nothing on the back
Thank you for any response in advance
PostPosted: Wed Mar 04, 2026 2:59 pm
A-D, 4 all high peripheral, can pull that antennae connector off if you want, I keep those separate to send in as gold plated pins
1-3, I'll get back to later (hopefully)
PostPosted: Wed Mar 04, 2026 3:44 pm
Thank you for the reply and suggestion
PostPosted: Thu Mar 05, 2026 9:52 am
1 I'm not sure but this might be good enough for high peripheral.
2 Low peripheral
3 remove the shield and antennae if you can, thinking midgrade as is, probably high peripheral after removing those two things, post another picture after.
PostPosted: Fri Mar 06, 2026 10:55 am
My guess is peripheral low-grade
Thank you for the response and suggestions
