It is currently Sat Nov 07, 2026 1:52 pm
 Post subject: Help grading
PostPosted: Tue Mar 10, 2026 8:46 pm
1 - 4 would they go as gold connector ends
1 Is cast aluminum connector ends
4 is front and back view
How would I grade this board
Thank you in advance for your reply
 Post subject: Re: Help grading
PostPosted: Wed Mar 11, 2026 8:45 am
1-3 I'd put in low peripheral.
4, are there gold pins in one or both of the black connectors? Looks like the white does not and the beige does.
Siemens, gold cap chip board. Might pull that L shaped bracket off especially if it's steel.
PostPosted: Wed Mar 11, 2026 9:27 am
Thank you for your response yes 1 - 4 all have gold pins
Yes the bracket is steel
PostPosted: Thu Mar 12, 2026 8:08 pm
So 4 I'd go low peripheral also. If there were nearly no gold pins I'd have been leaning midgrade.
