It is currently Sat Nov 07, 2026 1:52 pm
 Post subject: What grade?
PostPosted: Thu Mar 12, 2026 1:00 pm
I'm thinking these are peripheral LOW grade. I've checked and they are called 2-port ethernet adapters.
Two questions:
Are they already high grade AS IS?
If not, would they be high grade if I pulled the two metal pieces off?
Thank you!
Gizz
 Post subject: Re: What grade?
PostPosted: Thu Mar 12, 2026 7:59 pm
That's a gold fingered card, note the gold where it slides into a socket of another board.
I'm unsure if the metal ports are heavy enough to keep it from being a clean GFC. If they're steel I would probably try and pull them off.
