It is currently Sat Nov 07, 2026 12:12 pm
PostPosted: Wed Apr 01, 2026 9:14 pm
Got these boards from a Compaq server and need help determining how to categorize them. Will be posting more over time
PostPosted: Mon Sep 14, 2026 12:38 pm
The white chips are relays. #8. I'll say Low Telecom.
The other board. High Telecom. Easily. Nice quality board.
PostPosted: Mon Sep 14, 2026 2:27 pm
Does that have 4 sockets labeled for CPUs?!
I'm thinking it's technically a large multi socket server board if you want it sorted correctly. Price is the same as high Telco.
PostPosted: Mon Sep 14, 2026 2:52 pm
Good deal. Marked141. I just put the evaluation at High Telecom for just that reason. Rather than struggle about Motherboards or Server. A High Telecom evaluation got the member his due money.
I am waiting to see if some member will suggest pulling the processors and still submit as High Telecom.
PostPosted: Mon Sep 14, 2026 4:31 pm
Good analysis fellas! I sent them in as low telco and multi socket serve MB…in May. I got paid for those evals too. Thanks for the input!
PostPosted: Mon Sep 14, 2026 7:26 pm
Catwhisker wrote:
...I am waiting to see if some member will suggest pulling the processors and still submit as High Telecom...
The green fiber capped CPUs? Those are likely soldered on.
PostPosted: Tue Sep 15, 2026 1:08 pm
https://boardsort.com/escrapforum/viewtopic.php?f=7&t=1563
I may have given some bad advice on just submitting both as High Teleco..
See the link. What Lostinlodos posted.
I am glad I am reading unanswered posts. I am getting a lot of valuable information.
PostPosted: Tue Sep 15, 2026 7:34 pm
Always sort
:D
PostPosted: Sun Sep 20, 2026 2:15 pm
That old sorting thread makes the split a bit clearer, especially once server boards start blurring into telecom territory. Easy to miss when the payout is close anyway.
