It is currently Sat Sep 26, 2026 12:02 am
PostPosted: Mon Mar 23, 2026 2:21 pm
Hi, I have a lot of boards that were previously used in household appliances. Some control boards, some driver boards, inverter boards, etc. I don't know if they're even worth scrapping but would like to have them graded just in case. Some of these are also locked into their casings, so I'd also like to know if they can be scrapped in this condition. Thank you.
PostPosted: Thu Apr 02, 2026 12:16 pm
Awesome, thank you so much for taking the time to look at these.
PostPosted: Thu Apr 02, 2026 12:48 pm
I think I had started to reply to this and then fell asleep and lost the text. Never got back to it.
D:
I think the main thing I was going to point out was, do try to remove the boards from the plastic housings. A lot of these appliance type things are pretty easy to push on the plastic tabs and slide the board out. That and removing large heatsinks, as suggested, is usually beneficial.
I'll also note the amount of sealant can vary and may affect the grade more or less but the generally it will have an impact.
