It is currently Sat Sep 26, 2026 5:12 am
 Post subject: Boards vs Pins ?
PostPosted: Sun Apr 12, 2026 9:40 pm
*Motorola Type Forward EQ 1GHz (00dB-22dB) SFE-100-01*
I have these tiny boards here that I'm not real sure what I want to do with them yet. They range from 0dB to 22dB & on average I would guess that I have about 28-30~ of each value between there. I'm mainly wondering I suppose about the 4 large pins that they all have which are yellow or 'appear to be gold'. I also have not yet removed a board from the blue housing to see what the other side looks like yet, which I probably should have by now...
Wondering which category these would fall under if I removed the blue plastic from each of them &/or if I should just clip the 4 pins off of them & focus on that?
Thanks for any help on this one & I really hope the pics are decent this time, I tried to get really good ones this round!
 Post subject: Re: Boards vs Pins ?
PostPosted: Mon Apr 13, 2026 8:26 am
I have no idea what these are but if you can find a buyer for them, they're in the original packaging, they would be new old stock. In other words, worth more.
For me to tell it's scrap value you'd have to open one up and pull the board out. It looks low or mid grade on the side that's visible but something could be surface mounted on the other side that makes it a better grade.
