It is currently Fri Sep 25, 2026 10:48 pm
PostPosted: Sun Apr 19, 2026 4:02 pm
All help is appreciated! Thanks!
PostPosted: Sun Apr 19, 2026 5:00 pm
1, is a low grade board unless there's anything hiding under the heatsinks
2, I'm thinking at least high peripheral with the gold fingers and ICs, if the plastic around the LEDs can pop off that would be good but not essential (unless anyone else thinks the board can get a higher grade then I'd say definitely remove the plastic)
3, similar to the other post you made, high peripheral after the aluminum heatsink is off
4, low grade. The display may be hiding something to make it a better grade but certain displays can add value too and I'm not sure if removing it to see what's underneath would help or hurt anything here
5, do you're best not to break any ports or other soldered on components, you've lost all but one of the VGA port's gold plated pins and presumably some of a DVI port; losing those things can impact the grade, but in this case I think you can still manage high peripheral.
