It is currently Fri Sep 25, 2026 10:50 pm
PostPosted: Sun Apr 19, 2026 3:48 pm
Too new. Please just tell me what to do!
PostPosted: Sun Apr 19, 2026 5:11 pm
1, needs to have the faceplate and the steel shield removed for the best grade, as is it'll get mid grade at least, possibly low peripheral. The steel shield in this case may be soldered to the board which would require cutting or prying or both to get it off, the faceplate should just have screws or similar fasteners
2, low grade
3, high peripheral, normally the cable box is larger and has a shield lid that should be removed (the white outline on the board) but in this case it's so small I think it's fine
4, mid grade as is, there's enough things that should have precious metals that this would go mid grade instead of low. If you have the time to remove things you could remove the ICs at least, the relays would have copper and potentially silver plated electrical contacts. If you do the board becomes low grade
5, appears to be a high grade hard disk drive board. again be careful with the connectors, you don't want to break off the pins as they're gold plated.
