It is currently Tue Sep 29, 2026 11:54 am
 Post subject: Classification help
PostPosted: Thu May 07, 2026 3:17 am
needing some assistance with what categories these would go into? Each pic is a Front/Back of the board. Also, if one can be upgraded to a better group by removing something from it, please tell me what that would be.
Thanks
 Post subject: Re: Classification help
PostPosted: Thu May 07, 2026 12:09 pm
I'd lean more toward high peripheral on the first.
Second, agree it'll depend on the pins and if there's any gold plating. If there's any silver(Ag) in the silver (color) part then you'd be at least at midgrade.
Third, definitely pull the top board if it's socketed, if soldered try to cut whatever pins are connecting. I'd go ahead and remove the U shaped brace from the middle too.
Forth, concur
Fifth, as is with so much weight, high peripheral at best. Remove the brace and 8 transformers and I think it'll clear high Telco
