It is currently Tue Sep 29, 2026 11:54 am
 Post subject: Small Boards
PostPosted: Sun May 03, 2026 8:26 pm
I'm new to selling boards, what could these small boards be classified as?
Thanks!
 Post subject: Re: Small Boards
PostPosted: Sun May 03, 2026 9:36 pm
1/3, some sort of wireless boards, try to pop of the metal shields and repost to be sure on the grade.
2, cd/DVD board
4, low peripheral
5, pull the rest of the tub cable off, low peripheral
6, be sure to peel off the thin cable completely, probably high peripheral
8, pull the cable ends off, high peripheral
7, also high peripheral
PostPosted: Mon May 04, 2026 10:40 am
Thanks for the reply!
Ok, removed the shields from 1 and 3.
Also, I peeled off as much as i could the cable from 6, but it’s still visibly got some residue from the wire that I can’t seem to scrape off. Is that going to be an issue?
PostPosted: Tue May 05, 2026 9:56 am
The remains of the cable are fine; basically, you want as little wire as possible, so unless you have to cut, just unplug them.
I'm going with high peripheral on the two, if the metal antennae is steel, do pull it off also.
