It is currently Tue Nov 03, 2026 8:40 pm
PostPosted: Fri Jul 10, 2026 8:32 am
Pulled a batch of components off some boards and initially assumed a lot of these were MOSFETs. After doing some digging, turns out this is a mixed bag — several IPMs, hybrid ICs, a standard IC, and what looks like a bridge rectifier. Hoping to get some input on how these would actually be sorted/graded here, since I don't want to just lump them all together if they're not equivalent.
Here's what I've got:
1. D6SBN 20 — pretty sure this is a bridge rectifier based on the +/~/~/− markings, not a transistor.
2. STA811M — looks like an SGS-Thomson dual audio power amp IC, similar hybrid-module construction to the STK part.
3. MTD1110 — haven't been able to ID this one yet, hoping someone recognizes it.
4. IRAMS12UP60A-2 — Intelligent Power Module (IPM), ~15-16 leads, used in motor drive/inverter circuits
5. IRAMS10UP60B-W — same IPM family, different rating.
6. STK621-728S — Sanyo/ON Semi hybrid IC, thick-film power module, SIP-style.
7. LA6510 — Sanyo bipolar IC, small driver/op-amp style chip.
Question for the group:
• Do IPMs (items 1-2) get sorted differently than the hybrid/driver ICs (items 3-5), or does everyone just lump these into general "IC/component scrap"?
Appreciate any input — just trying to sort this properly rather than assume it's all one bucket.
Thanks!
PostPosted: Fri Jul 10, 2026 6:40 pm
General rule for ICs for Boardsort:
-must have at least 6 legs/pins/leads (3 on each side)
-generally no inline legs, if you're not certain it's an IC don't remove it.
-removing can downgrade your boards
So for the ones you know are ICs, I would either, confirm with Boardsort before mixing or keep them with but separate from your other ICs when you send them in.
Not sure on the other questions.
PostPosted: Sat Jul 11, 2026 6:38 am
My general rule of thumb has been similar to yours. I have only pulled 6 legged (or more) IC's (at least 3 on each side) or kept them on the board if they were a better grade. However, in the past, items such as these I have always thrown in my #2 bucket and wrote them off as mosfets. Now, with AI tools, I have become curious about different components and recently asked about these and they keep coming up as ICs.
