It is currently Sun Nov 01, 2026 9:25 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2, 3  Next
 Post subject: IC's and Dallas switches
PostPosted: Sun Jul 12, 2020 7:04 pm
Can someone post some pics of Dallas switches? I am having trouble telling the difference between IC's and Dallas switches... Google wasn't much help... Is there an easy way to tell the difference?
PostPosted: Sun Jul 12, 2020 9:15 pm
∆ this
And Mercury wetted relays
Given how important it is (hazmat)
It's hard to watch out for them having never seen one
Representin otown, central FL
PostPosted: Sun Jul 12, 2020 9:53 pm
Battery backed Real time clock IC boards: aka Dallas Switch
These are unacceptable
PostPosted: Sun Jul 12, 2020 9:54 pm
Battery backed real time clocks with batteries removed: peripheral rate
PostPosted: Sun Jul 12, 2020 10:03 pm
Mercury:
PostPosted: Sun Jul 12, 2020 10:04 pm
Also Mercury
Also Mercury
And finally you may see these on old equipment.
PostPosted: Mon Jul 13, 2020 12:38 am
tHANK YOU EVERYONE!
PostPosted: Tue Jul 14, 2020 1:15 pm
For mercury relays,
Attempt to remove or place whole board in hazmat?
PostPosted: Tue Jul 14, 2020 1:34 pm
For dip (IC) style, only ones in sockets. Otherwise the board is hazmat.
For canister style if you have enough experience to make clean breaks in a PCB you cou punch a hole around it and remove the can from the board. But generally best to hazmat the whole board.
For tube style they usually have a quarter or half turn socket. Push down gently and try to turn it. Some are clockwise some counter-c.
Mercury is a neurotoxin. Impossible to clean up in quantity without experience, and causes toxic stains in organics and cloth. If you aren’t 100 percent sure you can remove it safely don’t try.
