It is currently Sat Nov 07, 2026 4:35 pm
 Post subject: Id Please
PostPosted: Tue Apr 26, 2016 2:51 am
Can these go as gold con
What would these wires grade as (I may have been organizing my wires all wrong)
Broke this apart - what is dis juan
Thank you
Trying to see how embedding pics from Imgur works...
 Post subject: Re: Id Please
PostPosted: Tue Apr 26, 2016 3:56 am
First is all peripheral
Second board (3rd) is peripheral or telco. Depends on factors i can't tell from a photo
4 gold connectors not sure on audio, gold or silver.
5 wire
6 wire (and a bettery)
7 mixed silver on brass/copper, silver on nickel and nickel.
PostPosted: Tue Apr 26, 2016 7:44 pm
#3 will likely go peripheral. It appears to be a card reader of some type and I'm guessing the slot will take an SD card. The gold flashing on the board is not doing much to add value.
PostPosted: Mon May 02, 2016 9:10 pm
Are the ide cable connectors silver connectors?
PostPosted: Mon May 02, 2016 9:26 pm
They're gold
PostPosted: Tue May 03, 2016 4:36 pm
Great.
Also, I am not sure if I should be separating these or what.
I have a pile for all the typical wire connectors
Can I put all these in one pile, even with that plastic coating. Also, many of them when i cut the wire off leave a bit of insulation.
Then I have these from switches and sorts. Are these silver contacts on the little mound? What would these go as? Should I separate the ones that are tin coated and w/o (just copper with the contact)?
Lastly, I have battery pack with the tabs. Will those go as nickel rate?
PostPosted: Tue May 03, 2016 5:53 pm
Most of those silver /grey color ones fall into 4 categories.
Silver
nickel
Silver plated copper
Nickel plated brass.
Cut the edge. If there's another colour under the silver it's plated. (Boardsort takes it clean cut (no wire left) as silver plated brass class.
If it's solid it would be better locally.
PostPosted: Wed May 04, 2016 2:54 am
So then what about the copper, with the little silver contact? or even the grey, with the small contact?
Ill try to post a picture tmrw of what I have if I remember...
PostPosted: Wed May 04, 2016 3:48 am
Those rivet pegs are probably a low Nickel tinned brass alloy.
PostPosted: Wed May 04, 2016 3:50 am
I've never asked about clean copper so I'm not sure. National rate is $1.20-$1.80 Monday
