It is currently Sat Nov 07, 2026 4:35 pm
 Post subject: Something new.
PostPosted: Thu Apr 28, 2016 8:47 pm
Got my hands on these today
 Post subject: Re: Something new.
PostPosted: Fri Apr 29, 2016 1:29 pm
Looks like a pda or media player.
Will go cell class or more likely telco.
PostPosted: Fri Apr 29, 2016 3:08 pm
PostPosted: Fri Apr 29, 2016 3:15 pm
Is there anything you see that I should remove?
I already removed what I thought was the battery from the back it was beside the AAC chip.
And as always thank you for yalls time.
PostPosted: Fri Apr 29, 2016 3:25 pm
Looks like you got it all
PostPosted: Mon May 09, 2016 9:09 pm
Scanner reader tear down ??
From the the same scanner but some of the boards are a little different and a few had the tiny board attached front and back of same board
PostPosted: Tue May 10, 2016 1:26 pm
1) peripheral
2) all telco
3) should be ohkay for gold ram. If not telco. Rom modules are tricky.
PostPosted: Tue May 10, 2016 5:59 pm
The little scanner stays whole?
PostPosted: Tue May 10, 2016 10:02 pm
The piece with the shield? No. Please remove the shield if possible.
PostPosted: Wed May 11, 2016 1:02 pm
Ok no problem comes apart easily. It's Metal.
