It is currently Fri Aug 28, 2026 10:53 am
 Post subject: What is it
PostPosted: Wed May 04, 2016 4:32 pm
Would these be considered telecom or Goldfinger cards
 Post subject: Re: What is it
PostPosted: Wed May 04, 2016 5:03 pm
Remove the Dallas boxes they have batteries in them.
Leave the ICs in for gold finger card.
Take the ICs out for peripheral rate.
PostPosted: Wed May 04, 2016 8:38 pm
What is the dallas box?
PostPosted: Thu May 05, 2016 3:37 pm
Dallas semiconductor manufactured these and they most commonly contain either a non-volatile storage (for system settings) or a real time clock, either of which usually has a lithium battery inside.
PostPosted: Thu May 05, 2016 3:46 pm
Yes. Those are nvsr storage and have a tiny memory chip and a battery inside.
PostPosted: Fri May 06, 2016 12:56 am
So they were removed because of the battery inside. Would u put that as battery scrap or cbm after taking battery out or what.
PostPosted: Fri May 06, 2016 12:57 am
PostPosted: Fri May 06, 2016 1:46 am
You can not safely remove the battery from inside those.
The whole thing should be put in a battery bin at the electronics shop. (The chip block, not the board).
