It is currently Sat Nov 07, 2026 4:35 pm
PostPosted: Fri May 06, 2016 12:55 pm
I need help in order to grade these and properly identify them.
Thank you for all your help.
PostPosted: Fri May 06, 2016 3:53 pm
1) green brown fibre no metal
2) green brown fibre with metal
3) green brown fibre no metal
5) green brown fibre no metal
PostPosted: Sat May 07, 2016 8:26 pm
Question ? Now that one with metal is it profitable/worth the time removing the metal from it to make it green brown w/out metal ?
PostPosted: Sat May 07, 2016 8:30 pm
That's up to you, those caps use different types of bonding and/or glue. Unlike AMD K5 and K6 series caps, they don't come off easy. If you break it it goes as low as peripheral.
If it's still whole after removing the cap, and you have more than one then yes, if you can figure out a way that works for you that's worth the time and effort it may be worth it
PostPosted: Sat May 07, 2016 8:32 pm
I don't remove the caps from modern (p5/core+) intel CPUs. Not worth the frustration to me.
