 Post subject: Another set need i.d
PostPosted: Sun May 29, 2016 4:38 am
Thanks as always
 Post subject: Re: Another set need i.d
PostPosted: Sun May 29, 2016 6:36 am
This will take a bit. I'll get back ti this Sunday afternoon. Once awake.
PostPosted: Sun May 29, 2016 12:42 pm
1/2) Both peripheral. The springs boardsort doesn't take but you should get a gold recovery for them.
3/4) top peripheral.
Top peripheral.
Bottom... gold laminate.
Telco As is. Personally... id snip the gold fingers.. then cut it at the edge of the CMCs.
Toss the fingers in gold fingers. The bare wire in mixed wire (or make a gold laminate bin if you have more than a pound for a local yard) and put the ic/cmc part in peripheral.
5)despite the excess i believe there's enough offset for peripheral.
6)little one on the right next to the the big board with press switches, ig the contacts are gold peripheral if silver midgrade. Rest peripheral.
7)
Left to right
Top:
1)telco
2)peripheral
3)peripheral
4)gold connector
5)gold connector
Bottom
1)peripheral
2)peripheral
3)telco
4)peripheral
