 Post subject: Little board pieces
PostPosted: Fri Jun 17, 2016 4:05 am
Not sure what to put most of these in and have no clue on what the screwdriver points to but it came from the inside of a hard drive lid...
 Post subject: Re: Little board pieces
PostPosted: Fri Jun 17, 2016 6:03 am
Last pair the two small fingered boards will be telco. Rest of fingered cards are gold finger cards. The hard drive i/o pieces will be gold connector. Rest is peripheral.
Those tiny antenna wires usually have a gold crown contact end. (All Gold alloy shell)
Cut them off the wire and toss them in with gold pins (or keyboard backs hehe).
PostPosted: Fri Jun 17, 2016 6:06 am
Ah poodoo. You have a ram stick on the bottom row last pic. Ill go through this once I wake up. Sry.
PostPosted: Fri Jun 17, 2016 6:18 am
No worries rest up & if better pics are ever needed I'm happy to redo them. I try to get it good enough on the first time though so I'm not wasting time.
My lighting is somewhat poor I know but there's not much I can do about it. It's either too much and reflecting off boards or too little and casting shadow on the pieces.
PostPosted: Fri Jun 17, 2016 7:48 am
all left to right
Top to bottom
First pair.
Peripheral peripheral midgrade
Cd/dvd board
Second set
Peripheral peripheral peripheral peripheral
Gold connectors ... [s]filter[/s] And a screwdriver.
3rd set
Telco peripheral gold-ram finger-card telco telco
PostPosted: Fri Jun 17, 2016 9:00 am
The little thing from the hard drive lid next to the screwdriver is one of the air filters for it.
PostPosted: Fri Jun 17, 2016 11:07 am
Thanks to both of you and I didn't think the filter was anything of value but wanted to know what it was so I knew not to tamper with it or not.
Also on the pics that I did both sides of the boards, I think there's one in each set that you didn't I.d ..unless I just matched the count wrong.
