It is currently Sat Nov 07, 2026 5:14 pm
 Post subject: Motherboard Sorting
PostPosted: Thu Jun 23, 2016 10:54 pm
Do I have these categorized correctly, and is there anything I should do to these boards besides remove the battery, heatsink and CPU chip? I am posting front and back pictures with what I think that they are categorized as. Thank you for your help!
 Post subject: Re: Motherboard Sorting
PostPosted: Thu Jun 23, 2016 11:29 pm
Yep. Great.
Those giant bracket backs need to be removed, the screws are under the squishy plastic in the 4 corners of the sockets.
PostPosted: Tue Jun 28, 2016 9:48 pm
I have found that a pair of wire cutters or nippers will work in popping the plastic screws holding those brackets in place. Most of those brackets I have seen are steel and can go in your shred or heavy melt pile.
PostPosted: Sun Jul 03, 2016 12:55 pm
Yes the vast majority of back plates are steel. Check with a magnet. If it doesn't stick scratch it, probably copper.
You should get light iron for the steel ones though, not shred.
