It is currently Fri Aug 28, 2026 4:53 pm
 Post subject: Peripheral??
PostPosted: Fri Sep 16, 2016 7:25 pm
 Post subject: Re: Peripheral??
PostPosted: Sat Sep 17, 2016 12:42 am
Not sure about gold balls.
I think those are all peripheral.
But I would wait till for Lost to give his thoughts.
PostPosted: Sat Sep 17, 2016 12:52 am
What about the flat round black thing next to the battery? I think it's a battery
And the IC chip that fits into a "bridge" can i remove it?
PostPosted: Sat Sep 17, 2016 2:53 am
They all look peripheral
Not sure what flat round thing
switches may have gold balls but these look too new and to low end, consumer level for that. My guess is nickel if it has balls at all. It's probably copper line but if you remove it cleanly you won't hurt your value if that's all you remove
PostPosted: Sat Sep 17, 2016 9:05 am
PostPosted: Sat Sep 17, 2016 9:54 am
I would leave that ic chip.
This is what I have learned about removing ic'c: Board Sort will only take ic's with 6 legs or more. If it's mid grade or low grade it's ok to remove them if it's peripheral or higher leave them.
Maybe lost will comment on this and correct me if I'm wrong.
I'm not sure about that green thing it looks like it could be a battery to me but I'm not sure enough to say one way or the other.
PostPosted: Sat Sep 17, 2016 10:31 am
This is about the only ic's I will pull. These are about 2 - 2-1/2 in long.
PostPosted: Sat Sep 17, 2016 1:15 pm
Yes, the green thing is a battery and needs to go.
The round thing looks like a piezo beeper.
PostPosted: Sat Sep 17, 2016 2:43 pm
Yes, as far as I can tell is a battery based on the numbers and the photo of it in the other thread.
