It is currently Sat Nov 07, 2026 6:30 pm
 Post subject: Cell Phone Boards
PostPosted: Sun Oct 23, 2016 7:26 pm
Hi again - one last ID for today. The first set of photos is a cell phone key pad board front & back. There are some small black pieces of foam on the back side I'll pull off before bagging. There isn't much in the way of population but a lot of flashing so I wanted to confirm this one would be either mid-grade or peripheral? (I was leaning towards peripheral but wanted to confirm.)
The second set of boards is from the same cell phone - not much on that one either; it's got me stumped.
Thanks again for sharing your advice and knowledge and have a great rest of the weekend! - DB
 Post subject: Re: Cell Phone Boards
PostPosted: Sun Oct 23, 2016 8:53 pm
The first set will go cell class. I believe the second set will go Peripheral, but I'm not 100% sure.....they may still go cell class.
PostPosted: Sun Oct 23, 2016 9:04 pm
In all honesty your better off pulling the batteries out of the cell phones and selling them as cell phones with out the batteries. The boards are $10/lb and the cell phone less batteries are $3.50/lb and cell batteries are 90 cents /lb.
PostPosted: Mon Oct 24, 2016 1:45 am
Thanks rdw for your help on grading. I pulled that one apart this summer just to see what was inside. I'll keep the rest of the cell phones I'm sending in whole without battery. Thanks again - DB
PostPosted: Mon Oct 24, 2016 2:44 am
I've got a write up on phones in the help section
PostPosted: Mon Oct 24, 2016 11:59 am
I've done the same thing "just to find out what's inside". I know that $10/lb is tempting but cell phones are time consuming and then the board weighs 3/10ths of an ounce. I guess if you had a bunch of phones it might be worth it.
