 Post subject: Leave the chip
PostPosted: Sun Nov 20, 2016 1:06 pm
Should I leave the chips on the board or remove them and will they go as telco?
 Post subject: Re: Leave the chip
PostPosted: Sun Nov 20, 2016 2:26 pm
The one on your hand is a pentium class ceramic (low grade ceramic CPU)
The other one with the metal spreader, if removable, is 486 class
As long as one or the other is on the board you'll get telco.
PostPosted: Sun Nov 20, 2016 2:51 pm
If I trimmed off the gold fingers will that downgrade the board?
PostPosted: Sun Nov 20, 2016 3:31 pm
if you trimmed the fingers AND removed the CPUs the board would be peripheral.
You can remove the fingers, OR CPUs, but not both.
PostPosted: Fri Nov 25, 2016 7:13 pm
This again is an older full gold run board, from some Hewlett Packard equipment. Again very good material. Cutting fingers changes very little, as the whole board is gold plated under the masking of the enamel coating. Again this is a very high grade board.
PostPosted: Fri Nov 25, 2016 11:14 pm
The flashing layer makes little difference on these. It's not thick enough.
