 Post subject: help classing a few more
PostPosted: Mon Nov 21, 2016 9:18 pm
Not sure how to class these.
PostPosted: Mon Nov 21, 2016 9:42 pm
First photo; talk about strange!
Don't see these often!
The ram blanks will get telco in most cases.
The left board, I believe I see fingers for a peripheral rate, if not midgrade
The top left small board also goes in telco in this case.
Bottom right as is is peripheral. A serial board. Do NOT remove anything.
Small socket. The controller sits in the small dip socket. Ram/rom goes in the small socket. Plenty of expansion ports
Same board I believe
These will need to be reviewed on site. If the contacts (silver grey fingers) are gold it's definitely in peripheral. silver or nickel you'll get peripheral. If they're tin it's midgrade but the solder comes into play on these as well (tin contacts with silver soldier can edge into peripheral rarely.
This is a rare example I point to where if the fingers are gold and you have a lot (looks like you do) you're better off cutting off any gold fingers and taking the midgrade board hit as the fingers are heavy and thick and worth more as gold fingers.
PostPosted: Tue Nov 22, 2016 8:10 am
Thanks,the second and third pic are the same,there are three items in the first pic,and the fourth pic is another front and back the gold fingers are only on the back,
Again thanks for the help
PostPosted: Tue Nov 22, 2016 12:46 pm
I see now first pic left is a single board.
Telco
The last pic is going to have to be reviewed on site. My guess would be peripheral from experience but it needs to be scanned to determine what the silver and grey metals actually are. This stuff always throws them for a loop.
Again you're probably, but not definitely, in a better financial situation if you cut the fingers on these when they are on BOTH sides, but not single sided.
PostPosted: Fri Nov 25, 2016 6:52 pm
First pictured attachment, and your second, third are all from a piece of older Hewlett Packard equipment. They are full run gold plated boards. If you gently scratch off some of the enamel mask from the covered areas of the board, you will see the gold plating below. These are really good boards.
PostPosted: Fri Nov 25, 2016 7:18 pm
That second board isn't going to go any higher than small socket. I took the rather thin plating into consideration here in boosting it to small socket in the first place but yes those are older boards.
