It is currently Sat Oct 31, 2026 10:44 am
PostPosted: Mon Jun 09, 2014 1:42 pm
I'm scrapping out a bunch of machines from work and ran into these two curiosities.
This first is a RAID controller card from an old server. It's gold fingered but has what appears to be an Intel CPU permanently affixed. I'm not sure if I should drop it in the gold fingered bin or if it should be classed differently.
Upper side:
Under side:
Closeup of CPU:
The second item is a set of connectors from a IDE hotswap drive bay. All pins appear to be intact. I'm thinking these belong in cable ends but I'm not certain.
Side 1:
Side 2:
Thanks
PostPosted: Mon Jun 09, 2014 7:09 pm
Cable ends appears to be the best spot for your hot swap bay connector ends. I'll leave it to boardsort to grade the RAID controller.
