It is currently Sat Nov 07, 2026 7:15 pm
PostPosted: Thu Jan 12, 2017 10:01 pm
First I am sorry about all the pics. Just wanted as much detail in them for you guys. I am taking a break from scrapping for a little bit and am preparing a load for you and want the odds and ends cleared out too but not exactly sure if you accept them. Here are some things I have been saving for a while. Lemme know what you think of them. Thanks.
PostPosted: Thu Jan 12, 2017 11:33 pm
The rectangles are 8080/8086 class CPUs
The flat squares will probably all go as ibm/via gold caps.
Pins don't have a flat rate and aren't on the quote form. But you can send them in with your order. They get scanned on site with an XRF scanner which gives an exact and total composition and are paid out based on the value Of contained metals. Rates vary in majority of $2-$12 per lb. but can be considerably more (or less). It's entirely based on the total sum of metals including gold in/on the pins. Make sure you follow up with an email with your order number as subject giving them your tracking number and let them know you sent pins
Same premise as pins
These need a reply directly from Chris. Call or email.
Busted up CPUs run the scale of classes. If they're intact (all parts) and have their pins even broken they can get their original class. But if anything is missing they're gonna need to be reviewed on reception by Chris.
Bare caps fall in with the pins for needing a scan to quote
Do keep the scan items sorted though, caps from pins etc. They go in different bins.
PostPosted: Thu Jan 12, 2017 11:36 pm
Btw the caps are completely mixed up but the busted CPUs are Sparc
Moto foreign gold cap if they have pins
I believe Ibm via gold cap if they do not but not sure. I only sent one and was a long time ago.
PostPosted: Thu Jan 12, 2017 11:59 pm
Awesome thanks for the help
