It is currently Sat Nov 07, 2026 6:55 pm
 Post subject: Just more sorting
PostPosted: Fri Feb 03, 2017 9:31 am
Want to confirm that everything here is perif, all guidance and suggestions are welcome.
 Post subject: Re: Just more sorting
PostPosted: Fri Feb 03, 2017 9:16 pm
From top to bottom, here is my thoughts.
First photo:
A: Low Grade
B: Mid Grade
C: Mid Grade
D: Peripheral
E: Mid Grade
Second and third photos:
A: Peripheral
B: Peripheral
C: Peripheral
D: Peripheral
E: Mid Grade. Probably better to harvest the lone IC chip.
Fourth photo:
A: Mid Grade, too much blank space on the board to give it anything else. Harvest the IC chips.
B: Mid Grade, no IC chips anywhere to be found
C: Mid Grade, one IC chip. Harvest it with a heat gun
D: Mid Grade, no IC chips present
Fifth photo:
A: Telecom, good IC population across the board.
B: Peripheral
C: Peripheral
Sixth photo:
A: Mid Grade, no IC chips and only power connectors, so can't offer it Backplane grade.
B: Mid Grade, too many power components. Harvest the IC chips.
C: Peripheral
Last photo:
A: Peripheral
B: Peripheral
C: Mid Grade as-is. Remove the large transformer and it may get a bump to peripheral.
PostPosted: Sat Feb 04, 2017 12:15 pm
My photos don't give all of the details.
In the interest of my education, here are some more details on a few of the boards that make me think that they are perif:
6 -A has a 96 pin gold conn, and a 9 pin gold conn, enough to lift?
1 - B thought that dvi were gold, and on the back the is a small odd gold conn, gold flashed and a tiny IC
4 - c & D have 2 eth ports each, B - both connectors are gold pin
Thanks for all of the guidance
PostPosted: Sat Feb 04, 2017 9:31 pm
A-E
B is probably peripheral with gold pin adapter and IC chips
A-E (redux)
Agree
A-D
The two large ones I think would hit peripheral for the vga ports. Much like floppy boards. The two small ones, if those are modem cards like I think peripheral if not midgrade
A-C
Agree
A-C (redux)
A is borderline mid/peripheral but with no junk I'd lean peripheral. Small serial port and big gold bus port.
A-C (the reboot)
I can't see C getting any higher unless you strip off everything except the ports and ICs. Basics meaning not worth cleaning this. Midgrade
