It is currently Sat Nov 07, 2026 6:55 pm
PostPosted: Wed Feb 08, 2017 4:10 pm
Recently, I had the good luck to have someone give me a Dell 2600 Server to play with.
I know that it is has a small dual-socket motherboard. But, I have no idea what those gold-finger card1 and card2 with heatsinks are. They came from the slots right next to the CPUs (Xeon). I checked their serial numbers on the net but nothing showed up.
Help?
PostPosted: Wed Feb 08, 2017 4:46 pm
Correct
Gold finger card heatsinks off
PostPosted: Wed Feb 08, 2017 5:04 pm
Thanks.
When you have the time . . . any idea as to their function?
PostPosted: Wed Feb 08, 2017 9:50 pm
Those are voltage regulators. You'll find ones similar to this in most major brand servers (Dell, HP, IBM, SuperMicro, etc), and there's usually one regulator for each CPU/chipset. You'll find these as well with a pin/socket connection; not as pretty, and I believe those go (with heatsinks off) as peripheral.
PostPosted: Thu Feb 09, 2017 2:47 am
The ones with the large copper spindles on iron or ferrite go as peripheral
PostPosted: Thu Feb 09, 2017 12:44 pm
Many thanks to both of you.
