It is currently Sat Nov 07, 2026 12:37 pm
 Post subject: palladium contacts?
PostPosted: Sat Feb 15, 2014 6:51 pm
hello,can someone tell me if these are palladium contacts?and what's the value?thanks
 Post subject: Re: palladium contacts?
PostPosted: Mon Feb 17, 2014 11:39 am
Hello gauvis welcome to boardsort.com!
Unfortunately we are unable to tell you what type of metals you have in your picture.
Our specialty is in standard consumer computer electronics where most things are standardized and recognizable through standard photographs.
Your material will require some testing or at least be recognized by someone who has had previous experience with such a part, which we do not.
We have a x-ray gun at our facility that could be used to test the material but unfortunately it will not be of any help to you through this message forum.
I wish I could be more of a help.
PostPosted: Tue Feb 18, 2014 4:19 pm
ok thanks for the help.
PostPosted: Fri Feb 21, 2014 1:57 pm
hello again here are some more pictures.these boards i have a lot of them and they keep coming in.what would you grade these and how much are they worth. thanks again,serge
PostPosted: Fri Feb 21, 2014 2:47 pm
Gauvis,
Those boards look slightly processed, as if some of the more valuable chips have been desoldered and removed.
However, as long as the pins are still in those connectors on the end of the board AND nothing else is removed from these boards, I would be willing to throw those into our Telecom grade.
Normally harvesting chips from a board will result in a downgrade, but it appears that there is enough fruit on these trees to allow them to pass as Telecom this time.
