It is currently Sat Nov 07, 2026 7:25 pm
 Post subject: Ceramic Cpus
PostPosted: Wed Apr 05, 2017 3:23 pm
Just needed some help on where these should fall.
 Post subject: Re: Ceramic Cpus
PostPosted: Wed Apr 05, 2017 4:02 pm
Left to right
Double gold cap / dbl gold / dbl gold / pentium ceramic
Bottom
Pentium / pinless/ Motorola gold cap
PostPosted: Wed Apr 05, 2017 5:16 pm
Thanks Lost.
On the bottom row left cpu. Sun Sparc 3 with Pins. You said it could go as Pentium. Can the heatsink stay on for this? Is it due to the high quality of gold on the pins? I did notice that they were a deeper shade of gold, which I had heard was better.
PostPosted: Thu Apr 06, 2017 12:47 am
You're gonna have one hell of a time trying to remove the heatsinks from those. I've heard everything from boiling (Chris's idea) to heat guns to baking in a household oven on clean cycle (my former method).
Reality is all that works for cx and k6 CPUs but I've cracked so many of this design I don't even try anymore.
Pentium is the lowest class of full size ceramic cpu. The sink brings most of these to this grade. Anything larger (MCMs) smaller (Moto 64c and 66J) or thinner (AMD K6-2) with a sink goes AMD ceramic with metal caps.
Yes that would be a higher classed chip (up to Chris) without the sink but as soon as you damage it you're right back to pentium class, or worse. It's honestly not worth the effort of removal.
