It is currently Sat Aug 29, 2026 4:46 am
PostPosted: Wed Apr 26, 2017 3:56 am
Hi can you id these and does boardsort but these?
PostPosted: Wed Apr 26, 2017 12:59 pm
I've sent stuff similar before. The boards need an onsite quote. Meaning you'll need to send the board with your shipment, sorted separately in the package, and email them with your order number in the subject letting them know it's in there.
The board shell will most likely be a colbalt aluminium or silveride. On the low end they're peripheral but range all the way up to cell class.
That said most fall into peripheral and telco.
There's a gold inclusive alloy used in the defender series of products from the 90s; these can make cell class despite the metal but are rare.
The shield is a heavy nickel bronze. They don't buy them. You'll want to find a steel yard that also buys precious metals ; they would have an xrf scanner and may be interested they're worth $2-$3 per lb depending on your location.
I know it doesn't help but these really are across the spectrum.
PostPosted: Wed Apr 26, 2017 1:05 pm
So here's your breakdown in order
Secondary board. Peripheral-cell class
Shield : dirty nickel rate
Base board. If it's metal you're in the midgrade-peripheral range. For a polymer board up to telco (maybe higher) . If plated plastic midgrade-telco range.
Hence these needing on site review. Email or call boardsort and ask if they still take the bottom picture at all if it's a light plastic.
 Post subject: Thank you lostinlodos
PostPosted: Wed Apr 26, 2017 8:16 pm
Thank you so much for all your help lostinlodos knowing is always helpful.
