It is currently Sat Nov 07, 2026 7:25 pm
 Post subject: Gold Fingers
PostPosted: Wed May 10, 2017 11:46 am
Hi,
I received these in a scrap load and was curious about them. I believe that the blank memory goes as peripheral, and the all gold finger pieces would be trimmed gold fingers. What about the bottom Dell double sided fingers? Would I need to trim them as well?
Also what are the; all gold fingers, and the Dell double sided fingers from/for?
The all gold finger have a slightly ceramic clank to them.
 Post subject: Re: Gold Fingers
PostPosted: Wed May 10, 2017 3:32 pm
The top one is a blank and will go as gold finger card
The next two rows are spacers. If The the gold is on both sides it's gold fingers. If only one side it will be gold finger card
The last row is gold finger cards
This last row if the fingers are on BOTH sides evenly I'd suggest trimming here because the fingers are heavy. You'll get a better return for the fingers alone than the gfc rate for the whole card. The bare board left behind after trimming is low grade
