It is currently Sat Nov 07, 2026 8:09 am
 Post subject: Hard Drive Logic Boards?
PostPosted: Thu May 11, 2017 12:19 pm
Are all of these considered Hard Drive Logic Boards? Are all hard drive boards considered Logic Boards? I'm just not sure if 'Logic' specifies a specific type of hard drive board. Thanks for the help!!
PostPosted: Thu May 11, 2017 1:42 pm
Those are all hard disk boards
The only variable in hard drive boards is 5.25 in hard drives which have two boards, only one is a hard drive board: the one with the 64xxx chip on it. The other goes as peripheral.
All pictured boards here are hard disk controller boards.
PostPosted: Fri May 12, 2017 12:22 pm
What price range would the pictured boards be at?
PostPosted: Fri May 12, 2017 12:27 pm
They are currently $7.50/lb
PostPosted: Fri May 12, 2017 12:33 pm
So a 'Hard Disk Controller Board' is also called a 'Hard Drive Board' or are they just the same price?
PostPosted: Fri May 12, 2017 12:38 pm
They are the same, but will let Lost make final ruling.
PostPosted: Fri May 12, 2017 3:29 pm
Hard drive board, hard drive controller board, hard disk controller...
all the same thing.
PostPosted: Mon May 15, 2017 10:02 am
Great, thank you both for your assistance!
