It is currently Sat Nov 07, 2026 3:44 am
 Post subject: When is it not gfc
PostPosted: Thu Jun 01, 2017 9:15 pm
Is it gfc or peripheral?
 Post subject: Re: When is it not gfc
PostPosted: Thu Jun 01, 2017 10:08 pm
Those aren't fingers, they're pins. Making your otherwise lowgrade board peripheral
In order for a card to be a gold finger card it must otherwise be a peripheral level card without the fingers.
Cards that would be low or mid grade class without the fingers will go as peripheral when you have the finger connector on it.
That generally holds true for pin cards as well. Cards such as floppy drive controllers and tolk-net cards that would otherwise be low or mid grade cards go as peripheral because of the pins.
PostPosted: Thu Jun 01, 2017 10:18 pm
Thanks for the info they came from old equipment
PostPosted: Sun Jun 11, 2017 8:49 pm
some ag/ta caps on the middle board...hard to find...those are old boards
PostPosted: Mon Jun 12, 2017 2:10 am
Yep, early to mid 80s would be my guess off hand.
They look machined, not hand soldered.
