 Post subject: rambus
PostPosted: Mon Feb 24, 2014 7:38 pm
[url]can I remove the metal heatsink from rambus to upgrade the price?[/url]
 Post subject: Re: rambus
PostPosted: Mon Feb 24, 2014 8:35 pm
I believe you can. I would not bother removing if the heatsink is riveted on. if the heatsink has a clip or adhesive holding it on, you can use a flathead screwdriver to remove it.
PostPosted: Mon Feb 24, 2014 9:22 pm
Yes, kgryczan is correct you can take the shield off of RAMBUS and upgrade it to standard Gold Fingered Memory.
With the right tools it can be worth it. As he mentioned, some are easier than others.
