It is currently Sat Nov 07, 2026 1:54 am
 Post subject: Need Help Identifying
PostPosted: Wed Jul 05, 2017 5:07 pm
Could use some help identifying these? On the Power Supply Board, I would normally put it as mid-grade but it had the gold slide in. I have serveral of these Server Power Supplies. Am I better to trim off the Gold End and then put it in low grade or mid grade.
Thanks
PostPosted: Wed Jul 05, 2017 6:10 pm
Depends on the back side. But it needs bus support to be a motherboard. It's missing card and ram sockets, and the related IC chips. I'd say this falls into peripheral
The two ram boards are backplane. The third is probably peripheral
Think both clear telco
Peripheral on the left telco on the right
The large one is backplane the sell is gold finger card the one next to it (HP?) is
Peripheral with or without the fingers and the smallest one is peripheral as is. If you cut the finger it will be gold pin connector.
The power board will be midgrade no matter what you do. If you cut the gold fingers you'll get mid grade and gold fingers. Cut further back and get the nickel flashing blank with it and you'll have peripheral and a trimmed midgrade power supply. Hop you can follow that. :)
The other 3 are peripheral. Remove the heat sink and shields. And the wires. Those wires are usually silver/nickel btw.
