It is currently Sat Nov 07, 2026 1:02 am
 Post subject: More gfc ??
PostPosted: Wed Jul 05, 2017 9:46 pm
Would these go as gfc or telco? And if it's gfc should I pull the gold caps?
 Post subject: Re: More gfc ??
PostPosted: Thu Jul 06, 2017 12:03 am
you can slice the gold fingers off and you will get telecom for most all of them. the ones with the gold cap chips will be gold cap chip board. you should be able to pop the Zoran chips out and get a good rate for those depending on whats on the underside.
PostPosted: Fri Jul 07, 2017 9:13 am
There is only one gold leg chip on the bottom left pic would that make it a gold chip board?
PostPosted: Fri Jul 07, 2017 9:39 pm
That's a gold cap chip board.
