It is currently Thu Nov 05, 2026 11:48 pm
 Post subject: What are these boards?
PostPosted: Wed Jul 26, 2017 9:43 pm
I picked these up in a large computer scrap auction. Would greatly appreciate any help on how these would be classified. Thanks!
BayDog
PostPosted: Thu Jul 27, 2017 12:24 am
you would probably be best off trimming the fingers off and then the rest of the board would go as low grade. if you send them in as is, you will get a percentage of gold finger rate. You could send a message to Chris and he would be able to give you a rate (hopefully one good enough to justify not doing all the extra trimming).
PostPosted: Thu Jul 27, 2017 12:37 pm
Those are damaged production blanks.
As is:
The large single ones on top are probably gold finger card.
The small ones are memory cards or rom cards (depending on the final chip). They're going to go as finger card.
I second MLS here, first contact Chris and ask. They won't move much if at all on the larger ones but DS cards and many (not all) flash memory goes as gold ram. There's almost no weight to an empty card so they may be able to offer you something better than the generic class.
If they can't move on the class offer just cut the fingers off. you've got some nice weight in those fingers.
PostPosted: Thu Jul 27, 2017 9:15 pm
Thanks alot for the info guys and I will contact Chris about these cards.
