It is currently Thu Nov 05, 2026 1:34 am
PostPosted: Fri Aug 11, 2017 4:01 pm
So I have here three separate photos, all these boards come from radar systems I work on. The last photo are like logic boards, second are CPU's? and first is a silver finger board? and an antenna. What could these be worth??
PostPosted: Fri Aug 11, 2017 4:42 pm
Midgrade (nickel base, not silver, most of the time)
Green fibre with metal (PDS CPUs)
Peripheral
PostPosted: Fri Aug 11, 2017 4:59 pm
The mid grade antenna have iridium or something of that sort
PostPosted: Fri Aug 11, 2017 6:21 pm
I honestly couldn't tell you. Everything coming up order the numbers on the tag is for a thermostat. :(
As far as looks, it's possible. Looks like the common nickel antenna but iridium is another silver grey metal so definitely possibly. If it is my guess is telco. But I'm totally guessing, never came across an iridium antenna before.
Try emailing Chris and asking what he thinks. They're going to no doubt have to scan it on site though to figure out what it would be worth, if anything, beyond average classes though.
PostPosted: Fri Aug 11, 2017 6:27 pm
Taking what you said earlier, you actually work on these? Is this from a telecom station unit? I just pulled a patent for it, WiMAX?
I'm reading through to see if it tells me anything. And ground penetrating radar. Grr. Totally stumped.
Sorry.
PostPosted: Fri Aug 11, 2017 6:55 pm
Yes I work on these. These are all units that have been scrapped down. A co worker told me about the iridium thing.
PostPosted: Fri Aug 11, 2017 6:56 pm
The older antenna actually use to have gold I think. I have only two or three of those.
PostPosted: Fri Aug 11, 2017 10:15 pm
I've often seen gold and nickel, copper on low end ones. Never heard them using iridium but I see no reason it couldn't be.
