It is currently Tue Nov 03, 2026 9:01 pm
 Post subject: More chips
PostPosted: Mon Aug 21, 2017 11:47 pm
Will these fall in those category's
 Post subject: Re: More chips
PostPosted: Tue Aug 22, 2017 3:47 am
All but the A6 are green no metal
Those quarter size capped (more like covered or reinforced) AMD CPUs be they the APU or GPUs I've had go both ways. And it's entirely dependent on the person taking them in.
My suggestion if you have only a handful or less is toss them in no metal, but keep them in a single bag (packing tape them together)). If they disagree on that day they'll adjust it down without any issues to you.
I've even seen boardsort tell me no metal on one and with metal on an identical cpu.
If you have them in bulk, many dozens or more, email Chris your quote number and a photo after you fill it out. , whatever he says will lock it in one way or the other. Just to be polite when sending 50 or qpp borderline things (in general).
PostPosted: Tue Aug 22, 2017 3:53 am
For what it's worth most companies would buy the apu CPUs as clean green fibre and the FX 1st/2nd gen CPUs and matching OP chips as metal cap.
PostPosted: Fri Aug 25, 2017 11:38 pm
yea to be honest you completely lost me there if you can possibly explain that in lames terms as i do not know much of cpu's lol thanks
PostPosted: Sat Aug 26, 2017 4:27 pm
By comparison
What you posted is a reinforcing plate. To protect the cpu.
Vs
http://www.boardsort.com/cpg15x/displayimage.php?pid=91&fullsize=1
Which is a full thick heavy heat spreader
The top of the third picture you posted is pushing the boundaries a bit so that could go either way.
