It is currently Sat Oct 31, 2026 9:07 am
 Post subject: Board ID
PostPosted: Thu Sep 28, 2017 4:21 pm
Telecom?
 Post subject: Re: Board ID
PostPosted: Fri Sep 29, 2017 2:09 pm
The little one is peripheral due to the large zip connector on the end
Top left peripheral. Too much board weight to offset
Top right should be good for telco. You have a soldered cpu, bridge, I/o controllers multiple expansions. Multiple high end controllers.
Bottom big boy
This is where things get interesting. This is a relay repeater (in lay terms). It’s the same board as above but missing some stuff. I’d say peripheral. Despite the higher value controllers there only two, there’s no memory expansion and the card slots are missing. I’ll say peripheral on this one. Without card and memory slots I don’t see it making small socket.
