It is currently Fri Oct 30, 2026 9:40 pm
PostPosted: Wed Oct 11, 2017 11:09 pm
This is the bottom of pile sorry had so many I'm just trying to learn and want to double check
PostPosted: Thu Oct 12, 2017 12:27 am
P)peripheral
Q)yes gold plate, barely but peripheral
R)peripheral
S)peripheral
T)peripheral
U)peripheral (it’s thin flashing)
J)telco
K)peripheral
L)peripheral
M)see note
N)see note
O)peripheral (registers trigger pressure, speed ratings etc)
E)see note
F)see note
G)see note
H)peripheral
I)peripheral
A)cell class
B)cell class
C)telco (looks like a zen remote or tunecast)
D)telco
Note: these would be midgrade as is. What I usually do is snip the component set from the bare wire. The component set goes into peripheral and the bare wire into mixed wire.
PostPosted: Thu Oct 12, 2017 1:00 am
Thanks is that considered an ic chip on T (the bigger chip) if so would I better off stripping the board of the ics right?
PostPosted: Thu Oct 12, 2017 3:56 am
No, and probably not. I doubt you’ll pull enough ICs to cover the loss of the board’s value.
PostPosted: Thu Oct 12, 2017 3:58 am
Do you refer to the big rectangle at the top of t? No. Or the small square on the side? Yes.
PostPosted: Thu Oct 12, 2017 9:16 am
Rectangle on top it seems to be made of the same outside material as an ic and has legs similar to one as well but not semetrical and if not an ic what is it any idea?
PostPosted: Thu Oct 12, 2017 5:13 pm
Best guess is a custom multi component package.
I’m more of the curious type myself, honestly personally I’d want to know more than earn money on the board; I’d cut or desolder it and take it apart. :)
But that’s me. ;)
I doubt there’s anything overly valuable in it but I’ve found precious metals and diamonds in stranger places!
PostPosted: Thu Oct 12, 2017 5:15 pm
Besides; looks like if you can carefully remove it you’d still get peripheral on the board.
PostPosted: Thu Oct 12, 2017 7:00 pm
I don't mind making the money but I'm doing this more because I like taking things apart to find out how it works but I'll keep researching into it and tell you if I find out
PostPosted: Fri Oct 13, 2017 12:19 am
Your right I looked at a spec sheet it's kind of like having several chips in one with an outer copper casing then cased over with a regular ic casing. I doubt it's worth anything more then plane ic grade. But now I know.
